Electrical Gremlins
I have a Mk2 Skoda Octavia, 2004, 2.0 TDI BKD engine, its a bit of a long story!!!
2 days ago the cars immobiliser prevented the car from starting after nipping into the shops for 15 mins approx. I cleared the fault codes with a basic reader I was given for xmas and the car started an I thought nothing more of it.
Last night while driving on the motorway I had every light on the dash board light up, a loud bleeping then sounded followed 10 seconds later by the speedo/rev counter stopping working followed by all the non warning lights on the dash going out and the trip computer freezing. The car continued to run normally with no loss of power or lumpy running.
After stopping and clearing some of the fault codes the cars speedo and rev counter worked. The same thing happened when I was nearly home. Today I have had the same thing 3 times, while driving the short distance to and from work.
With thanks to DONOVAN this evening I have a scan of my car. I would be grateful if those of you with a far better understanding of these things than I could try and point me in the right direction. I have done some searching and the only similar symptoms I could find are related to a faulty cluster that may need replacing?
Wednesday,16,January,2013,18:16:34:55062
VCDS Version: Release 11.11.2
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Control Module Part Number: 03G 906 016 F HW: 028 101 139 1
Component and/or Version: R4 2,0L EDC G000SG 6201
Software Coding: 0000072
7 Faults Found
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame
RPM: 798 /min
Torque: 14.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101000
Torque: 162.0 Nm
Torque: 0.0 Nm
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
Freeze Frame
RPM: 798 /min
Torque: 14.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 6.0
18045 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller - Intermittent
Freeze Frame
RPM: 819 /min
Torque: 10.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
18043 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Freeze Frame
RPM: 798 /min
Torque: 12.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame
RPM: 966 /min
Torque: 6.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11001100
Bin. Bits: 11000000
(no units): 1.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame
RPM: 0 /min
Torque: 204.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Temperature: 0.9°C
Bin. Bits: 00110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame
RPM: 0 /min
Torque: 204.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Temperature: 0.9°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Thanks for reading
Have a look at the Ross Tech Wiki, but I would suspect that all but the glow plug faults are linked.
Without looking at the wiki I would suspect a wiring problem, possibly CAN related, but you would think there would be errors in the CAN gateway or other controllers and not just the engine controller.
  • 2 years later...
not to re open topic but did you ever find a fix i am currently having similar problems
