ABS problem
Hey fellas
any ideas with this fault code?
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No SW: 6Q0 907 379 S HW: 6Q0 907 379 S
Component: MABS 8.0 front H03 0001
Coding: 0000008
Shop #: WSC 13765 000 00000
VCID: 4D9B2B38D7CC34709A3
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
RossTech Wiki
Possible Symptoms
  • Control Module doesn't perform to factory design
Possible Causes
  • Wrong Firmware Installed
  • Failed Control Module
Possible Solutions
  • Update Firmware of Control Moudle
  • Replaced Control Module
Special Notes
  • When found on:
    • VW ABS modules, see TPI 2017922
    • Bosch 8.0 ABS module, see TPI 2008907
    • Skoda with Bosch 8.0 ABS modules, see TPI 2014687
    • Audi A3 or TT Steering Assist, see TPI 2021189
    • Audi A8 Electronic Parking Brake, see TPI 2016072
Anyone had this problem?
You have an abs light on the dash yes?
What have you done, simply tested for faults using vcds?
No abs light on dash. And everything seems to work fine. Just slightly worried as everytime I resd the car it pops up with that fault code.
Sent from my GT-I9300 using Tapatalk 2
