Diagnostics
Not for mine. Any one near me got anything that will get closer to a problem on a Laguna. Daughter has one which comes up as "injection fault" on the dash and then clears . Car is a diesel 52 plate Laguna . Could be worth a bikers while .
Edited by VWD
Is this classed as a engine warning light on said renault,
What horsepower engine is it as some older volvos use renault diesel engines in them
Comes on as a warning,. It's a normal diesel -possibly 1.9. When on ,it sounds like a moped is outside, some times chugs . Switch off ,leave for a few minutes, statr up and all is well . It's not an old un -it's a 52 plate . I'm worderin if it's DPF -mind you daughter is not known for hanging around . Any biker with software would get a welcome. SIL is a serious biker . She's now a convert to heavy oil- she likes the grunt ( and as she uses it for work -economy- she's now listening to dad)
Edited by VWD
Maybe worth trying vcds and seeing if it will pick up anything through OBDII, I used my cable on a vectra and picked up a duff spark plug.
Don't think DPF was around on cars of that age (Euro-III compliant diesel?) but if you don't find anyone to help you can always pick up your own scanner like:
http://www.ebay.co.uk/itm/Universal-Maxiscan-MS300-Fault-Diagnostic-Scanner-Code-Reader-OBD-II-CAN-EOBD-UK-/200833634896?pt=UK_Diagnostic_Tools_Equipment&hash=item2ec29e1250
to read off the fault codes yourself - pretty sure it should be compatible with the Laguna. :D
Chris
