Doors Not Unlocking With Key.
So my auxiliary belt snapped on Saturday and the car sat for 2 days with a dead battery. I picked the car up this morning and its all working great. The vibration when I accelerated has gone too.
But now when I open the doors remotely, only the driver door unlocks and the passenger and rear doors don't. How do I change this.
Sounds like what I have on my Fabia - incorrectly-coded convenience unit.
Possible other symptoms:
Key too probably just opens the driver's door.
Passenger side can still lock driver's door - which increases the risk of locking-in the keys!
I'm no expert but as I recall the unit has to know which wires to send its signals down. There are different codes for 2/4 doors, left/right hand drive etc.. I'm guessing your code died when the battery was disconnected. Perhaps there should have been a backup battery to maintain it but that has run down?
My unit was replaced a couple of years back, when my (independent) servicer spent ages trying 'every code he could get from VAG-COM' without success. At the time I saw quite a lot of information and even some suggested codes on Briskoda. I've not (yet) managed to find it again.
So you may have to consult a main dealer (est. £75 if all goes well). That's what I'm doing on Thursday and I'll let you know if it works.
Mine was like this after a battery change last year. It went back, the garage took the earth off the battery for a few hours, put it back on and all was hunky dory. No problems since.
Gaz
Gaz
+1 :thumbup:
You'd be surprised how many niggles that are CCM related, especially central locking, which can be cured by resetting the ecu/ccm. Disconnect battery for an hour or two and see what happens.
I said I'd report on whether my visit to the main dealer worked. In short - no. Whatever code my servicer found seems to have been about right. There was no suggestion that the unit was duff/damaged/incorrectly installed. They said something about the passenger-side control unit: I suspect something else has been lurking because:
1) The rear wiper sometimes operates on ignition,
2) The alarm was forever going off - until in sheer desperation I removed the siren fuse (F60 in a Mk1 Fabia: I might try putting it in again).
They'd estimated £75 but it was only £45. Still a lot for no improvement but (no doubt touting for servicing/sales business!) they threw in a general look-over and flagged up a broken spring which I can get repaired before the MOT.
I asked and the code should survive a battery disconnect. I'd wondered because I'd lost the one-touch window operation - now restored.
Do I need to take both connections off the battery or is just the black wire okay? Lol! Can I leave it overnight disconnected?
Just the black one (earth) will be fine.
Gaz
Gaz
Thanks. Left it off for an hour today and it worked! Happy days :)
