Lowering octavia MK1 HOW LOW ?
How much can i lower a mk1 octavia safely without running in to sump problems catching speedbumps and cracking etc i will be using lowering springs on standard shocks however not sure how low to go as it is my daily driver so need it drivable and comfortable .. Mine is a 2006 MK1 so has the 1.9 PD 100 bhp.
I'd say 30 mm springs if you would like to keep the ride comfortable and everything safe ie the sump
Well where i live we dont have speed bumps but mountains, i'am lowered and well i've got mines set ideal on coil overs i'll upload a picy in a bit, firstly i got to get the kids to school
If you are going to use standard shocks you dont want to go any lower than 35mm as you will ruin your handling and destroy the shocks as they are probably fairly old .The best thing is to buy a kit like wietec i had the shock and spring kit it was very good 35mm lower on a vrs .but if you want to go lower try ap coil overs these are made by kw/wietec and cheap.
Thanks sesachc i am looking in to lowering springs only not coilover setup would still like to see a pic of your car thanks
Would like to see pics of 30-35mm lowered octavias on 18-19" wheels if anyone has any.
  • Sponsor
As mentioned on standard shocks I'd stick to around the 30mm area.
If I can be any help with prices of info just let me know.
Damian @ DPM Performance
this is the car lowered now
and this is the car standard springs
i should mention though, it's tdi spec shocks, not vrs, but lofty had vrs shocks and lowering springs so maybe he'll be along shortly pic whoring :D
love looking between these 2 pics, shows how much shes changed
Ps Winter wheels + fiance passed her test, i still got my spiders but keeping them safe for now :D
