Maxi-DOT
is it possible to retrofit maxi-dot display, without having skoda car navigation system or symphony radio?
I can't see why not, as long as you had someone on hand with VAG-COM to recode the dash pod immobiliser codes..... hopefully Lummox will be along shortly :D
Chris
You can probably fit it, but the MaxiDOT is driven by the SatNav unit (only). The Symphony does NOT drive it at all.
From the pictures that I have seen of the Maxidot display it can work without the Sat Nav, im sure it would just come up with an error message if you tried to select the "Sat Nav" option, obviously if it does need the Sat Nav then spend another
The whole lot.
It's just an all in one unit, pull one out, stick the other in simple as that!
oh and recoding of course which either your dealer could do or someone with VAG-COM :thumbup:
