Fabia vRS Coolant Temp Sensor
Can anyone confirm the part number for this part please? Is it the grey oval switch, as I have heard of green ones also?
Also, as it is in such an awkward position that I cant see, can anyone tell me how it connect and removes please.
I have seen the guide for the 1.4 but can't see about how it is held in place and how the sensor lead attaches to it.
Cheers :)
Its a 2 pin plug, have not got the part number at hand, its on the right hand side of the block, removing the maf and pipe makes it abit easier. Around 30 from tps, and 11 from euro.
Done this on mine a while back easiest way is leave sensor attached to the cable then take c clip that's holds it in place out and give it a wiggle should just pop out followed by about a litre or so of coolant but not much! With the cable still attached to the sensor it's makes it easier to remove it and manovere it about so u can change the sensor over! Didn't need to remove the maf but I did have the engine cover already so that helped
Just make sure u get a new c clip and rubber washer when u get the sensor! And yeah it's the grey one a skoda techie told me it was the green one but ended bein the grey one
