Octavia Mk2 1.9 tdi bad starting when warm
Hello my mate has a octy 1.9 tdi 105 bhp starts fine when cold but cranks over for a while when warm has anyone any idea? drives and mpg fine otherwise. Mine starts just the same warm or cold. many thanks.
I believe this has previously been traced to one of two faults.
Either the battery is passed its best, or failing that the starter motor is on its way out.
Basic theory is that when warn the engine needs to achieve a particular turn over rate before fuel is injected which the dodgy battery/starter cannot easily achieve. Whereas when cold, fuel is injected immediately.
HTH
Thanks that would make sense as the car was at the dealers forcourt for 7 weeks before he got the car. i didnt realise the classics had so little spec either it doesnt have a flip key is this right? many thanks
HTH
I have the same engine and was experiencing exactly the same problems you describe. I changed the battery and its been fine since.
Hope this helps.
Just sorted him a varta E11 Hoping this sorts it! Will soon Know! Thanks
Just rang me said its sorted it. many thanks
