d.m.f or s.m.f
Hi all I am getting vibration when I pull away and suspect the dual mass fly wheel is worn out,
I have read that you can replace this with a solid flywheel but I don't know which way to go . My local independent Skoda / V.W garage say to stick with the original .Has any one had any experiences with fitting the solid one .By the way I tow a caravan
regards
Stick to original. I've seen several people having problems after changing to SMF. Not instantly, but after a good use.
just replaced my clutch and flywheel after 170k
went for the sachs after being recommended on here.
flywheel and clutch kit just over £300 from euro car parts with briskoda
discount of 25%.
i also tow a caravan and worked on the basis that if it lasted 170k
hopefully it will last till in knackers yard. :giggle:
discount of 25%.
Either i'm blind or you forgot to point out which one you went for. :-)
sorry
:giggle: dmf as original.
cown
i think you will find that they only fit dmf
from new so all the clues were there :hi:
cown
Sorry mate, you are right. :-)
I had a smf & not for to long, as after a long distance drive I would come to change down & it wouldn't go into gear, massive smf fail so went back to the dmf. I would stick with the dmf I think.
D.M.F.s seem to have down in price quite a lot recently, probably because so many are now sold. This was the main reason for fitting S.M.F.
Thanks to everyone for their help and advice
Hi Mate,
If you drop me a PM with your reg no I could price one up for you..let me know :)..
Kunal
Hi Mate,
Kunal
Thanks for that but i have booked it in at our local independant v,w skoda garage £600 fitted
