2.0TDi Clutch or Gearbox squeak on gear change
All seems to work fine on my 58 plate, 1ith 110K. But there is an annoying squeak at the end of each upwards gearchange, which I presume is a linkage needing lubricating.
Anyone else share this, or managed to resolve by adjustment or lubrication ?
Definitely a clutch squeak, Off to the mechanic in the morning
Interested to see what they say. Mine has the same noise from the clutch pedal when changing gear (only done 6k) so off to the dealer to take a look next week
Can't provide any info i'm afraid as mechanic was too busy. Was booked in for pad/disc replacement. Next week for road test.
Good luck
mine was sorted. No new parts needed. It looks like the pedals attach to a torsion bar and it was clipping that bar which made the clunking noise. all sorted. Only took about 30 mins to fix it.
