low boost vrs
hi guys,
bought my 1st vrs - it seems a bit sluggish - so i downloaded an app on my phone that links with my obd device and it can show me boost pressure.
you can feel the car hold back after an initial surge and its settling anywhere between 5-6psi - im sure i read these should sit at 10 psi?
does anyone one have an example of what the boost curve should look like?
cheers
chris
5 6 is low no eml light? you could do with getting the car logged with vagcom , could be number of things might even be running in limp mode
no engine light - ive scanned on my code reader for faults or any stored ones - but nothing... its a bit hesitant when coming on boost also
no smoke out it and it doing pretty good mpg
N75 valve?
Which app is it ??
torque
Don't trust it for boost I can't get it too match what my boost gauge or VCDS says. it's ok for temps etc, but it seems to struggle with boost.
it feels very sluggish and you can feel the boost drop back quite a bit
sounds dv related
Just swapped dv for known good one. Still the same. The hoses all seem to be ok too
Might be worth checking the pipe under the inlet manifold. Mine had same issue as yours and it was a slight crack in the pipe.
Yeah I had look at it today and it seemed fine
  • 2 months later...
Sorry to drag up an old post but I have exactly the same issue as this and still cant resolve it. Did u find the problem in the end?
