Data off a laptop HDD
Might sound daft, but I have a IDE/Sata to USB hard drive connection kit to access data from regular hard drives. My mum's laptop has given up (was powering up, but not booting up it seemed) so I am wondering if I can get the data from it? The drive is one of those little ones that pushes in at the end and "meshes" with slots in the laptop - appears to be a bunch of about nine pins, small gap, then bunch of 4 pins.
Hopefully a kit exists for this too?
From the description, it does sound like the hard disk is just SATA - so that would be fine. Could you post a picture of it, just to be sure?
Sometimes, manufacturers will use a non-standard adapter between the disk and the laptop connector, which usually just pull off the disk to reveal the standard IDE or SATA connector.
I doubt it matters but its a 40gb drive.
As said by Craig... sounds just like a normal SATA connection - there will be no problem plugging it into the adaptor.
Just beware.. if the drive is dying, and the machine you plug it into recognises and asks to scan it - say no!
Ive recently used this free windows tool to recover info from a dying hard drive: http://www.piriform.com/recuva - it can take a while (as the hdd will be trying to recover itself in the background) but in my case it got about 90% of the data back
Does that plastic bit with the pins detach from the rest of the drive?
OK. It's definitely a SATA disk - but that grey bit on the end is one of those manufacturer-specific adapters I mentioned. Try to prise it off gently with a small flat-blade screwdriver. It should then reveal the standard SATA connector :)
This..
Actually on closer inspection the drive is still in a "frame" - there will be four screws either on the sides, or the bottom securing them together
it does :D I was wondering how the hell the SATA connection was meant to go on :D Trying it now. Cheers
OK - Its talking, but won't let me look at it until I format it.... That's not the idea! LOL
I can now hear the drive making little laser gun type noises..... I only want to be able to read it without having to format it.... [sigh]
Time to fire up some file recovery software :) A good start would be the free PhotoRec.
Aha! Finally let me in and I can see Mum's "My Documents" folder.
Great success! :D
Brilliant news! Such a relief :)
Yeah - Mum will be happy. She was going to take the HDD to her tech people at her university department, but no need to worry now. :thumbup:
Copied about 400MB of stuff on to my own PC so at least have a backup now.
