A Newbie Again.........Honey I'm Home
Hello Brisky,
I'm back in town after 3 years absence in the Vauxhall world.
I have bought my old VRS back as it was up for grabs. A few Little issues to sort out from a VAG COM Scan (no boost), but very happy with my purchase. It's a 2004 vRS 103k £1500.
Test drove and deposit paid today.
Just waiting for the plates to transfer away and I can collect her.
Looking forward to the Skoda world again.
Edited by mluton
Nice nice nice! Welcome back :hi:
Nice looking VRS and good price too! Welcome!
Right i have bought ready for when i collect her to get to the bottom of the boost problem
VAG AUDI VW 1.8T RECIRCULATING DUMP VALVE BLOW OFF BOV (As a test piece, as it has a Forge 007 fitted by me last time)
Wynns 54101 500ml Fuel Injector Intake and Carb Cleaner (Bit of cleaning)
Mass Air Flow Meter MAF cleaner - new - for ALL CARS (Bit more cleaning, I replaced the MAF, just before I sold her so hopefully a clean will do for now)
K&N 57i Induction Kit (57-0430) for Skoda Octavia (Not a carbonio, but the carbonio was removed by the reseller when I traded, so cheap this time round, brother in law is making me a heat sheild)
Hopefully a bit of tinkering and Boost will return, unless a its a split pipe, then more purchasing to do.
Just waiting for a couple of N75 vlaves to end on ebay.
VAG COM Errors were for ref:
Check DV
MAF Flow Error
Secondary pump incorrect flow
I know this car very well and had all the errors in the past myself, so hopefully no mare to sort.
Edited by mluton
I wondered when you would re-appear, I see common sense prevailed lol
Welcome back
Welcome back
Cheers mate, Yep will be lurking around now and bugging everyone with my Issue's. :)
Welcome back chap. :thumbup:
Waiting for collection now
Only 8 hours till I pick her up. :)
"it's good to be home again!" welcome back
Now on my drive. <br /><br />null_zps425f7a95.jpg<br /><br />Things to do list over the next few weeks<br />Check Boost block 115 VAGCOM <br />Clean or new maf<br />Clean or new map sensor<br />New n75 valve<br />Clean throttle body<br />New Clutch pedal <br />Parking sensor buzzer reconnect<br />Remove tow bar<br />New Tyres<br />Wheel alignment<br />Handbrake adjust <br />New Temp sender<br />Reactivate Cruise control<br />New brake light switch<br />Fit 57i<br />Fit eBay dv or recon 007 dv<br /><br /><br /><br /><br /><br />Re write this on a pc not iPhone <br /><br />Sent from my iPhone using Tapatalk
Edited by mluton
To do over the next few weeks, not in this order
Check Boost pressure, block 115 VAGCOM
Clean or new maf
New n75 valve
Clean throttle body
New Clutch pedal
Remove tow bar & electrics
New Tyres
Wheel alignment
Handbrake adjust
New Temp sender
New brake pads
Fit 57i
fit New Pollen Filter
Been toying today
My Octavia vRS with Piper Cat Back Exhaust, Cheap eBay Diverter Valve and K&N 57i From Front
My Octavia vRS with Piper Cat Back Exhaust, Cheap eBay Diverter Valve and K&N 57i From Rear
Nice daps .......
Replaced a few bits including the temp sender and boost has returned, hopefully boost is sorted now.
Sent from my iPad using Tapatalk HD
So correct me if im wrong, youve fitted the ebay Diverter valve and a K&N, and even though its a resirculating valve, you can clearly hear it dumping.....?
Sounds lovely. Away to search Ebay.......... :evil:
Yup
welcome back Matt..
hard to stay away from mk1's as they are such a bargain now too :D
