Help on removing B-pillar trim
Hi I'm after a bit of help.
The Mrs' Fabia had the issue of leaking door carrier seals.
No i've sorted that thanks to the guide on here but now i'm wanting to get the rear carpets up to get rid of excess water left behind as we cant fully get the car moisture free.
Problem i'm having is getting off the trim covers on the B-pillar's so I can get to the carpet.
I've removed the seat belt outer clip but I cant free off the trim. I have a set of trim removal tools but it just feels like I'm going to snap something when I'm trying to get it off. Is there a certain trick to getting theses damn things off?
Any help much appreciated.
bump
It's in two parts. The top part is easy, pull from the top. The bottom part I have difficulty with and always seem to manage to break it. They don't cost much more than £10 from a dealer.
Edited by anewman
Instructions from Skoda manual
– Pull off top part of bottom trim panel -1- in direction of
the tailgate.
– Insert a long screwdriver into the retaining clips and
release the clips -Arrow A-.
– Grab the trim panel -1- at the loose part and loosen
bottom part of trim panel by pulling upwards -Arrow B-
(if necessary slacken with screwdriver).
Installing
– Recondition the clips ?item 3 in 70-3page 2 in the
trim panel of pillar B or replace with new ones.
– Press trim panel -1- with clips into pillar B.
– Place door seal into the correct position.
Hope that's more help to you than it was to me :)
cheers folks, will give it a try in a bit
