Cooling fan noise
Hi guys,
On my Octavia cooling fan started to make quite annoying noise. Better then describing it I recorded a video. It is quite clear to hear it when u put volume up and after a switch off engine.
I think it could be fan itself, but I don't know.
So any idea what it is causing it and how to fix it, or does it have to go garage?
http://www.youtube.com/watch?v=yeUCymbbFjU
No one?
1. Get a VCDS and check error code .
2. Depending upon hardware ( FAN1 or FAN2 ) get wiring checked which attaches to the coupler . A good electrician would be able to do so .
Sounds like your air con gas is low.
Had that sound before!
I booked it with dealer to repair it
Had the same noise on mine, re-gas of the climate system fixed the problem..
17 degrees on the Climatronic, in March!?
Mines on 24 :giggle:
