interior light not working?
I have just fitted a bluetooth unit following what i have forund on here and not i have one spare black screw torx head and not able to find the place it came from.
Also as it says at top nothinging on the interior light works now?
Any ideas?
Thankls for you help
Mick
ok done some investigation and fuse ok, have power to the plug and all the bulbs are working but interior unit not working at all reading lights not working and interior light won't work on dorrs or when switched on.
Any ideas or is it just a new unit?
Mick
Has the metel plate on the back come lose or off as thatswhat carries power to the lights. And the screw could be from the glove box. Should be four screws in the top and one on left under the end dash panel, and im sure its two along the bottom all the same screws.
Thanks Matt
I put the Bluetooth unit under the drivers seat and removed dash that side. Found out I had missed the screw under the bonnet release catch. Looked at the metal strips and found if I connect a battery on the bench the unit lights up, confused now
Mick
No contacts on the plug or socket bent?
Does not look like it and rear interior light is not working now either? Going to look at relays behind drivers panel to see If i have knocked one.
Mick
  • 8 months later...
Mick,
Did you get anywhere with this problem.  I have just found the same fault.
Craig
