Engine fail light flashing...
Hello everybody,
I have had a periodically flashing of the engine fail light... After running througt a VAGCOM, the following was shown:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 016 DJ HW: 028 101 188 3
Component and/or Version: R4 1,9L EDC G000SG 6250
Software Coding: 0000071
Work Shop Code: WSC 73430 790 00000
VCID: 6ED9D061798C249
1 Fault Found:
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 32.0 Nm
Speed: 61.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001110
Torque: 164.0 Nm
Bin. Bits: 0 01 0
Readiness: 0 0 0 0 0
Can anyone tell me how to change the brake light signal, and what the part number is for a Octavia II 1,9 TDI?
Thanks...
I was going to say brake light switch before I even opened the thread.
Dead easy to change, just above the brake pedal in the footwell.
Mannyo, thanks... Maybe you know a guide online of how to change it on an Octavia. The only ones I could find is on Golfs and so on.
What part number do I need for chaning this???
it should be the same part and instructions as a Golf MK5, so if you have found instructions for that then follow those.
