4x4 poly rear trailing arm bushes?
hi, found out today that my rear trailing arm bushes are shot. Could anyone tell me if they are the same as non 4x4 arm bushes,? i have tried looking for poly ones, but cannot find any, i can only find listed poly ones for normal octavias. cheers, Ralph.
If you want superpro: SPF2536K
Those are £120 because they are adjustable,ouch! would the Mk1 tt or S3 ones fit ? powerflex do them for those cars for £47.
No idea about powerflex, or whether S3/TT/R32 had anything other than normal bushes
When searching it'll be much easier to find stuff listed for S3/TT/R32 than trying to search for Octy stuff
According to ETOS the partnumber for the bushes is 1J0 505 203 and they are listed as fitting Octavia 4x4 & R32/S3/TT. If you have or intend to lower your 4x4 you will need either the track control arms from an R32/S3/TT as they are slightly different to the 4x4 arms or adjustable bushes like the Superpro ones.
Don't think those superpro bushes negate the need to change the tie bars if lowering
The bushes allow toe adjustment, its the camber which is primarily effected by lowering
