Stream Mp3, cd changer & cage
Upgrading to a Bolero, and won't return it back to standard in my ownership so gonna sell my standard set up.
Stream mp3 with code
6 disk changer
Cage for changer
Cable from front to rear
If poss the AUX lead
Everything to retrofit it into a basic set up
Much would I expect to get for this, quick look on ebay leaves me unsure on prices
G
The Code would make it that little bit more sellable, but I wouldn't hold out much hope for much money anyway. Have seen Stream/MP3 going for £30.
When I took my Stream MP3 out, I boxed it to keep (along with the fascia) so when it comes to selling up and moving on, I can put the original HU in and sell the 310 separately -or- install it in the next car.
Without a code the stream is useless since a purchaser will not be able to get the code. The only person who can get the code is the current owner, with proof of ID and the V5 from the car it should be fitted to which should match the address on the proof of ID. Without this Skoda will not issue a code, otherwise there is little point in theft prevention coding.
Sorry it'll have the code also... Forgot that
G
I was going to stick mine up at £50 but yours is more newer than mine and with a code too.
