Do all seat leon have 312mm brakes as standard
I mean all seat leon cupra 1.8ts
No, the MK1's didnt all come with 312mm brake set ups fella :)
How can I check if they are 312mm
Tape measure!
Is there away to measure a disk or just top to bottom
Top to bottom with wheel off
My fr tdi 150 leon only has 288's
Cupra 180 should have 312 and 256 setup
I have just been up look at them and they are 312mm and got everything for £80 bargain
Result! Need to find me a bargain like this.
mine didn't have 256mm rears
I think only the lcr got the 256 rears
Have s3 got 256mm rears
Yes but they are 4wd aren't they? I have been told 4wd rear brakes will not work on ours.
they will. they need a spacer though. I think 3mm..
well thats the way it is for the mk4 golf anyway.
mk4 Golf is a different car though? I thought jas had 256mm rears from something 4WD and they didn't work, even with spacers
You always seem to fall apon these mods u lucky ****a!
Boxy™
As andy says they wont work on a fabia even with a spacer.
So is it just octy Vrs rear brakes will fit then
Edited by Dav-Vrs
Boxy™
Haha have you seen the seats I have brought lol
and Cupra R, and the Anni mk4 Golfs
Ah right ok. 2wd 256s will fit though will they??
The 170bhp v5 bora and seat toledo had 312mm fronts but not sure about the vented rears
Yeah, but the 256 rears seem less common. I went with the safe option and got the Octy vRS rears for about £70 (but I already had discs and pads)
Do the 2wd drive audi tt have 256 rears? I know the 4wd ones do
The early Tt 180 had 239 solid rear set up. The 225 had the 256. The lcr has 256 with the 2 wd carriers. So has the golf mk4 anniversary. The v6 4 motion and mk4 r32 have the 256 with 4 wd carriers. The 256 with 2 wd carriers will bolt straight on. You will have to make a mod to the rear splash guard. Don't try and fit the 4 wd version as these do not fit. Some Leon run Lucas calipers on the front which run the 288 front discs and some run the ate calipers that can run 288 and 312 with a carrier change. If the carriers have cast number 301 on them you have 288 front discs. Hope this helps
