Numpty mistake ..
Well i started off today with a list of to do jobs on the vrs
1 re hang the exhaust with new rubbers - it went well the tip now sits in the cut out properly with no excess movement
2 change the spark plugs for ngk r - simple and fairly quick
3 drop oil change filter and replace - done
4 change thermostat and rubber done now to the re assembling i had the theremostat pipe and rad pipe back on alt plugged back in now to put the metal plate back that bolts to the inlet and to the crack dipstick pipe broken :(
im now faced to drop the new oil strain it to make sure its got no bits in then drop and clean the sump and while im there check the oil strainer
so ive priced up some sump instant gasket and the dipstick tube from GSF car parts but does anyone know what the part number is for the turbo oil return gasket is ?
cheers
