trying to get my 4x4 off the ground
right then my 4x4 has been off the road for ages now and i have had a few setbacks and things get in the way of me starting it, now i think the time is right and things are good to go.
trying to sort out a few things and get my head around some other stuff and straighten out my plan with some suggestions from you lot, i have looked around alot and my mind is all over the place :rofl:
going to fit the cast wishbones from an r32/tt with the part number 8no 407 166/165 so while dropping the subframe might aswell put some nicer bushes in there
looking about its suggested that SPF3397K super pro bushes are the items of choice for the wishbones any others needed?
what bushes do people swap out for the subframe ones? cupra r? or tt ones?
am i missing anything that should be done while its dropped? i have already got steering rack bushes upgraded
are there any better top mounts that can be used for my coilovers ?
lots of questions here i appreciate hopefully all easy to answer
when i get going i suppose a build thread is in order :wonder:
cheers guys
use TT rear arm bushes - good price from ecp/carpart4less
might as well do front bush while you are there
standard topmounts are fine, again lemforder from ecp are good if yours need replaced
consider new ball joints if old ones are past best, and finally r32 arb and new bushes for it too
Cupra R topmounts are better, but expensive with it. There is also Powerflex topmounts available.
Leon cupra R top mounts on mine, work great.
I have the full superpro kit on mine front and back, tightens the handling up no end (however i did fit R32 23mm front and Neuspeed 25mm rear ARB at the same time) :happy:
do you know which superpro pack numbers i should be using for the 4x4 with the cast wishones, is it pretty much anything from this list, obviously bar the engine ones?
http://www.superpro.....aspx?MenuID=31
Edited by boomsly
For the cast wishbones you need bush set SPF3397K (rear with castor fix) & SPF3394K (front)
You can use all the bushes for the rear end.
You get two choices of lateral control arm: SPF2540K (standard) is the one to use with adjustable tie bars
Good to see you getting the project started again :thumbup:
- what kit have you already got ?
parts wise i have a full ko4 engine to fit
o2m 6 speed, s3 shifter on the way, got the shafts and prop, stater/ bolts mounts etc BUT have considered going vr6 clutch and g60 flywheel and staying 5 speed
cast wishbones and the super pro bushes with SPF3397K and SPF3394K
kw v1's in a box
brembo 4 pot fronts with 330mm discs
rears hopefully sorted a set of 256 vented
tie bars im in group buy for so on the way later, comprake ones so will need SPF2540K
hunting for r32 arb's
FMIC
and clive at cntuning has kindly said he will come down to sort my mapping out :thumbup:
much lower spec than i wanted originally but once i hunt down a blue haldex it should make for a nice car to drive about in
sussing out what bushes for where is confusing a bit but im getting there with all this help :clap:
Edited by boomsly
The short ratios gears of the 6spd box are setup for the higher boost threshold of the K04
More LSD options for the 6spd boxes as well, should you get the funds
You should look at H&R matching ARB set too
there is that thought that i would eventually get to a similar setup as yours as your on spool and boost/ power delivery are perfect imo including the diffs
getting the 02m makes sense while everything is out and simpler to achieve and get it working in a more basic setup
if i do fit diffs then i will be doing the diesel 6th and more power too, but that is a stage for later on
what manifold/downpipe are you onto now? very interested in your full spec, pm me if its easier
Sounds like a plan :thumbup:
I'm on an APR Australia equal length under-slung mani at the mo, specs PM'd
