Dash lights?
Hi all Just got a 2013 Montie didn't think about the maxi dot till after pick up is there any way 2fit it afterwards or if not change from the green lights in the dash pod?? Cheers
You can fit the maxi dot version - and then just recode the dash with vcds.
The second possibility is to change the SMD led from green to white in the dash pod. /difficulty ****-/
Edited by siekla
Cheers ill look in2 that but can't imagen the maxi dot pod will b cheap lol can u just get 1 for a same year monti or do u have 2get a certain 1?
Not at this moment but will keep an eye on it
