Just wondering what people think?
I went and looked at a leon today for my brother in law. Ran a full scan and it picked up this..
Saturday,13,April,2013,15:31:06:62402
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R026439 Mileage: 126070km/78336miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FN
Component: 1,9l R4 EDC 0000SG 3358
Coding: 00002
Shop #: WSC 06441
VCID: 61CFEAAFEBBA68104E2
VSSZZZ1MZ3R026439 SEZ7Z0B1634257
1 Fault Found:
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 336350E751C6AA80ECE
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0004
Coding: 13113
Shop #: WSC 06441
VCID: 224DA5A3AE3C3308178
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 902 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 04402
Shop #: WSC 00000
VCID: 2859B78BC800D95849C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: F0E91FEBB050519851C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 E
Component: 2V Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06441
VCID: 397F62CF23AA50D0262
Subsystem 1 - Part No: 1C2959802A
Component: 2V Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C2959801A
Component: 2V Tõrsteuer.BF KLO 0004
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1M0 035 186 F
Component: Radio 0001
Coding: 00401
Shop #: WSC 06441
VCID: 2B534887D9F6F240A4E
2 Faults Found:
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s); Rear
End ---------------------------------------------------------------------
Has anybody had this come up before. I have had a google but it says that it could be something as simple as the car has been run out of fuel recently or something as serious as..
  • Start of Injection Timing Regulation not OK
  • Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
  • Engine has stalled / ran out of Fuel recently
  • Wiring/Connectors from/to Injection Valve (N108) faulty
Just not sure as the car generally seemed ok and without my new VCDS cable I would have been none the wiser.
Thoughts please</p>
Bit more info about the fault here http://wiki.ross-tech.com/wiki/index.php/17656/P1248/004680 although it does cover the things you mention.
I personally don't worry too much about a lot of codes that come up, providing the car is running properly and everything works. A simple momentary glitch can cause a fault to be stored. I scanned my car when I got it and it showed a fault with the wipers. The wipers have always worked fine so why worry about it.
I would not be so worried if it was something like wipers but its the fuel pump bit that gets me! It needed a cambelt replacing as well and Im pretty sure I could hear a tensioner struggling to turn freely.
but having said that it was a good price :happy:
I'd clear the codes and scan again in a week or two. As JB says, the slightest transient issue can store a code.
You might well find the code never comes back!
