2 quick questions (service history receipt and rear speakers)
Ok I was having a look through service history to see when my cam belt needed changing and found a reciept from 2012 I just wanted to make sure that i'm not seeing things and that it looks like it was done?
Also why do the speakers in the boot (next to the parcel shelf) have 4 wires? is there a tweater in there? I was trying to install a sub onto the standard head unit using the speaker wires and built in HP filter but the sound is weak (converter on its way)
Four wires is two for that speaker then two go to the tweeter in the rear doors. And from that receipt its had a new head gasket due to loosing coolant somehow so oh ad a cambelt at the same time
Looks like it, but it's not clear is it? Was there an invoice to go with it?
If it's from 2012, you could well be able to phone up the garage and ask them to look into their records.
Thanks for the info guys really big help!
gat5569xs is the part number for a Gates timing belt.
