How do you upgrade front light bulbs in mk2 Octy Vrs?
Hello,
I want to upgrade my headlight bulbs for more powerful once but when i've tried it's quite difficult to remove the cover to remove the bulbs! Can anyone please let me know how to remove old bulbs and put in new once? I've done this before years ago in a Ford Escort which was dead easy! The results compared to standard bulbs was fantastic! :)
Remove the headlight:
You will find a white plastic wing nut behind the headlight cluster.
Unscrew this and remove to a safe place
At the front base of the cluster there is a body coloured hook .
Pull this..Its quite hard first time...I used a cloth around it.
Its then a simple matter of gently coaxing the headlight unit forward.
To remove it completely you will need to remove the wiring plug (Easy)
To replace make sure you line up the unit exactly or it will get stuck.
It just slides back in.
