Flickering ABS dash light on Fabia TDi
When the ignition is first turned on, during its self check the ABS dash light flickers instead of being fully lit.
I now have some fault codes but not on the ABS unit which is fully working.
I suspect a dry joint on the ABS controller module. possibly on the can lead
Is it possible to examine the connections on the ABS controller board or is it a sealed unit?
Is this a known problem with these units?
Today the ABS light was flickering, closing the passenger door cleared firmly the fault again.
Many thanks for any help on this.
Dougal
Below are , the fault codes which have been stored by this fault.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00188
Shop #: WSC 13765
No fault code found.
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Shop #: WSC 13765
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 13765
1 Fault Found:
