Coding westphalia dedicated towbar wiring
Hi
I have just fitted a towbar to my yetti (2012 140tdi 4wd SE) using a dedicated wiring kit from Westphalia.
It was a bit of a PIA to fit as there was no towbar pre prep on my vehicle so all the wiring had to be run to the front fuse box. I got it all fitted properly in the end, and all the basics work - but I am not sure how to code it using the VCDS to turn off the rear parking sensors etc.
According to the westphalia instructions I just change the setting to "coded" and follow the instructions - but I presume this is only if you are using thier own test kit.
Using VCDS the new module is recognised - but all I can change is the long code - and I do not know what to change it to.
Can anyone advise me ?
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Not registered 0001
72-Door, Rear Right -- Status: OK 0000
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 070412F2000109
Coding: 356303
Shop #: WSC 35110 377 09999
VCID: 3A712C31B544B89
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 8907 km
Time Indication: 0
Date: 2011.14.15
Time: 10:14:25
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030198165
Coding: 0100000100000000
Shop #: WSC 00000 000 00000
VCID: 30650E196338729
No fault code found.
John
Edited by RoryRover
Have you gone to module 19 - CAN Gateway and ticked the box(es) for trailer / towbar then saved this?
That may fix both issues.
Hi Karl
I had not done that - but I have now and sadly I still get exactly the same error messages.
Thanks for the suggestion.
John
Doh
I forgot to clear out the fault code from module 19 before re-scanning.
I have now done so and re-scanned and everything comes back OK, and no faults found
Thanks for the help.
John
No problem. Glad it's sorted.
Check it again after a few drives just to be sure that the fault codes haven't come back, but I don't think they will.
