drl activation
I have a 56 vrs with the lower fogs. if I go to my garage and ask them to activate drl via vagcom, will those lights be on when the sides are off, or does it only work if drl are fitted?
sent via Playbook and Tapatalk
A 56 vrs won't have DRLs. You may be able to enable sidelights to be always on but not sure what purpose that serves as in daylight they're barely visible which defeats the object.
If you have it activated your fogs & sides will come on when ignition is started.
ok, ta. just curious more than anything else. is that legal to run both when not foggy or needed? thought you'd get pulled for that....
I think they run at reduced output, I've been stopped once & explained that they were drl's and they were fine about it.
If the fogs are used as DRL's and use reduced output will they be abled to be used as fogs by turning them on. Or are they now just DRL's, will they be on when you select dipped headlights
People will think you have your fogs on
No they turn off when sidelights or dipped are turned on.
