paranoid about oil usage
Hi there
As the title says i am paranoid about the oil usage of my vrs (CTHE) after everything i have read on here, Just checked my oil, having not even done 500 miles yet.
This was the result, i dont know how much oil was put in at the dealers, maybe it wasn't filled but would be interested in people's thought's?
Do i need to top it up now? and if so what oil is best to use?
Many thanks :happy:
Is that it dipped when cold or after being brought up to 'Normal Running Temperature' then checked after a few minutes?
george
george
Thats dipped after a good run temperature was about 91 on maxi dot, and left it for 5mins parked before I checked it
Thats how the Manual tells you and shows.
Also check it when cold and see where it sits please.
Just to see where it does show on your dipstick.
I take it you read the Skoda Fabia Owners Manual.
Personally with 3.6 litres of oil in, i expect the oil to be at the top of the hatched area.
Be careful not to overfill and ask the Skoda Dealer what they do at the PDI.
What matters is that you do not use too much when running the car and you top up when required.
That does not really look too low, just lower than i would run it,
if you put it to the top of the cross hatch you might find the oil temp sits at 90*oC or a bit below..
george
Here is one with dirty Oil the other day, dipped cold.
Oil at the Top Orange marker,
& that is at the top of the Cross Hatched when hot.
Yeah I did read the manual, ok thanks for your help, I will dip it cold and see what I get
Sent from my GT-I9300 using Tapatalk 2
Trev, I'd just dropped my oil, changed filter and refilled with Castrol Edge Professional LongLife III 5-W30 oil, 3.6 litres of it as per the book and my dipstick shows the oil level at exactly the level your picture shows. Mind you, when I got it from the dealers it was showing higher, between A & B (as per manual) on the stick of horror.
If I were you I'd not top up at all. Just leave it and check every other fill up or so.
looks ok to me, car usually comes back after a service with the same measurement, as for paranoia, just keep an eye it, I had breather mod and oil usage checks and so on, now I just top it up.
Enjoy your car, I have found oil usage reduces when you push on with the vRS.
I will just leave it as it is then, and just a check it every tank for now, thanks for your help
When she's hit she needs to be run hard mate!
Mine is at that level and been there since 3000 miles now done 4500 CAVE engine
lol.. @ tom... to OP... just leave it .....
still not topped up since 10k (48k now) :p CAVE engine :p
( I have to keep posting, just to prove there are good engines out there ;) )
That's a good place to be on the dipstick IMHO.
ok thanks, just wasn't sure and didn't want to be driving around with it low
