Internet Help Required
Can anyone give me some advice on accessing a website i used to go on?
problem is that if i try to go to the site i get the,this page cannot be displayed page and some info about ssl 2.0 and 3.0 which are enabled and pct 1.0 which isn`t listed ? i can access the site from other pc`s so i don`t understand why i can`t get on from mine,i`ve tried deleting history and cookies but it doesn`t work and as i`m not good with computers then i`m baffled so if any advice could be offered can it be put in basic terms for me so i can understand it please
regards
Dan
Sounds like a problem with IE. Have you tried viewing the site from a different browser just to see if it works and is not a problem with your ISP. Firefox seems a good alternative, download from http://www.mozilla.org/products/firefox/
Do you keep getting a message like this one?
Or is it just me? :confused:
You'll be wanting www.puretna.com, bigger hard drive anyone :D
Thanks Mannyo,i will give that a try and see what happens :thumbup:
and Tavia i think i have seen that message before ;):rofl:
Downloaded mozilla and use that as my browser now but still can`t access the site i want,any other suggestions? mannyo also said it could be something with my isp,whats that then? please excuse my lack of computer knowledge,they just baffle me :eek:
Try restoring your pc to a point in time when you were able to access the site.
You will need to go into control panel & then select performance & maintenance, system restore should be on the left hand side near the top of the page.
Hope this helps.
or try setting IE back as your main browser and visit windows update and get all available updates, it might just be that you haven't got something that you need
You may need IE - and you may need to set it to prompt for a username/pwd instead of blocking it and/or auto-loggin on with local credentials. Hard to be sure without seeing the settings
