Timming Belt - Replacement
Hi All,
New driver - Novice here, i purchased a Octavia MK1 L+K but not sure when the timming belt was last done, any way of checking this or is this not possible unless you take it out?
Although ive read on forums 4years or 60k miles some say 80k miles but i needed to know when to change this without changing the belt for no reason if its been changed previously. Last owner was trade and they took it in p/x so are unsure about when it was done.
Second thing is a hear a loud clunk everytime i turn the steering - parked of course. Full circle left or right makes a loud clung like a spring noise any ideas?
Your thoughts would be most appreciated.
Octys are quite prone to the front springs breaking, that could be your noise
Sent from my GT-I9300 using Tapatalk 2
Personally, if i had no history of a cambelt change on a car (with sufficient miles on it). I would change it.
There is no way to tell how long it's been on by looking at it. They look completely fine until they fail so if you don't know change it along with the water pump
Double post
Edited by Frisco
Definatly get the timing belt done, along with the water-pump and tension-er.
Thanks guys - I took it to the garage raf spot on about springs. :)
I guess i will have to get it done, i was trying to work out from 60k it was last done speaking to Skoda. So i would assume next one due 120K,160K, 220K
But do you guys know if the timing belt can last beyong 60k, as most other cars go on for about 80K until you change it. Its a 1.9 TDI ASV (non pd) engine if that helps.
Kool thought it'll be a broken spring
I'd stick to 60k, too much of a risk to go any further
Thanks guys just got it serviced and timing belt changed with tensioners and water pump plus two front springs. Drives alot better. Although 110 feels sluggish on top end.
