Rear caliper recon kit for VRS MK1?
http://www.ebay.co.uk/itm/230970214364
Is that the correct one for the mk1 vrs? I'm deciding on reconditioning both rear calipers. Offside rear caliper piston the rubber boot has split in two!! 41mm piston?
Edited by sammyhale30
38 IIRC
Not sure of the size. but i got a set for my Octy VRS after the old ones were perished and made the piston hard work to press in.
You get piston fluid in the kit too, that helps bed the seal and piston back into caliper. Think it was £8 from TPS
