Clutch or gearbox
On the way back from my partners mums my gearbox started making a funny noise but I'm not sure whether its due to the clutch or gearbox I know that the real ease bearing has been a bit noises recently the noise disappeared when you pressed the clutch down is it possible for that to collapse I need to get it towed to unit 18 but I wanted to see if I could shed some light first
"real ease bearing"? Did you mean the thrust bearing? If so, then the symptoms you describe could be a failing bearing yes.
Thanks I'm hoping tht it's salvageable a bit of a better discription is when your driving the gearbox sounds a little like a rally cars gearbox with te little whine goes when clutch is pressed to the floor and now it just sounds like something is kind of grinding sound but not if you know what I mean
Could possibly be the thrust bearing on its way out
It's the first thing I'd check; Unit18 will probably have standard and upgraded brearings and clutch kits (and SMF conversions too) in stock.
With the work involved in removing the gearbox I'd consider replacing just the bearing to be a false economy as a general rule.
Thanks ken i spoke to Ali and he suspects main shaft bearing but he will be collecting it at some point handy having him on the doorstep what ever it is I think it's going to be expensive :-( damn cars lol
