How low?
Hello
I recently bought some 17" 8.5j wheels and I'm also buying some coilovers from DPM.
I don't want to go low low, I need to retain some practicality, I was thinking 50mm front and rear, or I'm I going to run into massive issues?
pictures would be great if possible.
cheers
Adrian
Sent from my HTC One X using Tapatalk 2
Depends on the offset of the wheels mate, lowering 50mm is quite a lot, the VRS is already 20mm lower than standard IIRC
50 is fine, mine was a standard car, and ran into issues around 85mm drop, the drive shaft hits the chassis
offset is ET52
i have 15mm and 20mm spacers
THanks man!
15mm spacers will give you et38, 20's will give you et33. 15mm ones will be the best for avoiding arch rub, i had et34 on the rear and they caught a bit
Edited by Lofty79
go arch rub go, et 38 yeah!
budget spacers, ooosh!
  • Sponsor
50mm is quite a bit on top of the already lowered VRS suspension but that's the joy of coilovers, just trial and error until you get a height that suits your needs.
Damian @ DPM Performance
thank you all !
Yeah budget yeah, get your spacers out.
i am on coilovers that allow a 60mm drop and i have removed rear adjusters making around 70mm and front helpers to go to 75-80 mm and im on 18" wheels and 225 tyres i had to get thee rear arches rolled but she is all good and speedbumps arent much of an issue just have to go slower lol
