Parking sensors
I am currently looking at buying my vrs. I have found 1 which has parking sensors.
What should the car do if they are fully functioning?
I have done a quick search but can only find info on mk2 systems.
Does it need a standard headunit to work?
No it's not linked to the headunit in any way, there's a separate speaker somewhere in the passenger side B pillar.
It should beep once when you put the car in reverse to tell you it's active.
Thanks il listen out for it when I next view the car
drivers b pillar :happy:
Really? The other wiring runs down the passenger side. Mind you I'm deaf in one ear, so can't tell where sounds come from.
yes i only know this as i removed a loom recently, the other loom is indeed on the passenger side, but the little speaker is in the lower b pillar cover
