Fuse location
Would usually refer to the owners manual, but its not present, so where does the fuse go for the alarm siren please, on a 1.4 16v elegance? :D
I could also do with knowing where best to get replacement fuses for the battery compartment too. :thumbup:
Fuse 60 on the vRS, would it be different on a 1.4?
I expect it to be fairly similar as it uses a fairly similar remote central locking system, so I will check fuse 60 tomorrow. :) Does it will tell you what ampage the fuse is rated to as well, please?
Thanks :thumbup:
I thought that website had been taken down, unless you took it on from Stu?
As Matt says, Fuse 60 15A (from the owners manual)
