Skoda Fabia
hi all was woundering if anyone could help iam getting a knocking noise on the front of my car i have looked all over the front end of my car i cannot see anything loose or broken the only thing i have not checked is the brake pads can theses or could theses come loose
this only happends when going over bumbs or pot holes i have even drove the car and slightly held the brake pedel on and noticed the knocked noise stoped soon as i release the pedel the noise is back again i thought i would ask hear before thinking about striping the brakes
any info would be great
Edited by Hawk1976
did you check the top mounts
top mounts have been checked and look fine
Brakes don't knock, they squeal, hum, maybe rattle. Things to check are engine mountings, broken springs, suspension bushes, ARB droplinks, shock absorbers, loose wheelnuts. That'll keep you busy for a while.
Edited by Soot1e
thank you for the info all of the above has been checked the problem was the brake pad was jumping about when hitting bumps or pot holes two of the clips had broken where the pad clips into the piston all sorted now
once again thank you all for your help
Easy fix then :happy:
well pleased with it your other reply i did check all off the above before checking brake pads thank you :thumbup:
