Faulty Passenger Wing Mirror - FABIA II 57 Plate.
Unfortunately the remote manual joystick control for the passenger side wing mirror is not fully operational.
Can this fault be repaired?
Or will it require the replacement of the whole wing mirror unit?
The remote manual joystick will currently move the wing mirror once but then no further adjustment can be made using the joystick.
The only adjustments can then be made by hand.
After a short period of travel and time the vibrations moves the mirror and it needs to be adjusted again to use for safe driving and parking.
It would be ideal if you have a step by step procedure to be followed to inspect, repair and last resort replace the wing mirror with a remote manual joystick.
I will look forward to your comments and advice.
Thank you in advance!
