Sign of cost cutting Octy 2 FL vRS fusebox
Been doing the planning for my ICE install and just looked at the fusebox for power pickup.
Now I don't need a huge amount of power, planning to use the bolt on OEM 40A fuse that I used on my 8P A3, so Octavia fuse box looks the same as my A3, but instead of individual bolt on fuses, it seems to have a plate with amp ratings written over black blocks with the cable bolted on below.
Luckily there is a spare free non-fused bolt on the plate to the right of the feed cable.
The individual OEM fuses are only £3.50 each but if you are un-lucky and one part of the plate blows it is £9.20 to replace it.
