Wheel fitments
Hi guys, sorry if this has been covered before but I was just wondering what I should look out for when buying new wheels, obviously the pcd and that I'm fine with its the ET and offsets? Or are these the same things?
What does those thing do to the wheel or what can I not get away with running without spacers?
Hope this makes a vague sense.
Will
Et is offset, usually et35 on 17" fabia wheels but u can go into the 20's or less depending on height and tyre strech
Hope this helps
Tom
Hope this helps
Tom
Okay thanks mate, what does the offset do to the wheels or the place on the car?
Will
The lower the offset number the further the wheels will stick out. 30-35 is about the best for a fabia
Thanks mate will do some research!
Sorry to bump this but,
Do you reckon 7.5J fronts & 9J rears with an ET of 30 will be okay?
Will.
Will.
Yes assuming the tyres (at least the rears) have a slight stretch.. 205/40s will be perfect.. and 195/40s on the front to match the slight stretch :)
Sweet! Think i may of just found my new set of wheels :D
Now need coilovers :D
