how do i remove dash board on vrs?
trying to get boost gauge hose from engine bay into cabin. Anyone know how to remove top of the dash so i can get the drill to where i want it?
There is a grommet behind the glovebox to feed the boost line through and ive got a 3 pod gauge above my stereo but if not id put on the steering wheel cowling so u dont destroy the dash. May not be to everyones taste when u come to sell + removing the dash is a pita just for a boost gauge. Hope this helps.
Yep there are a couple of holes you can use (oo-er!)
thanks guys. Is the grommet behind the dash easy to get to from the engine bay? I don't really want it visable, just want it to keep an eye on things. Just had to have the turbo core replaced because of a hole in a pipe i didn't know was there. I
Remove the scuttle panel passenger side (pull directly up from the windscreen) and one is next-to the pollen filter
It comes out behind the glove box (5x torx screws to remove) about here:
