Which Pagid brake pads for a Mk1 VRS?
Euro Car Parts seems to list loads, any idea which ones are correct as I assume they are different? Seem to make far more mistakes than before as I ordered a fuel filter using my VRN and it was totally the wrong shape!
I'm sort of wondering this too after having a look a few nights ago.
I think the difference is to do with disc diameter, if you look at specification you will see the diameter of the disc the pads are designed for, just measure your disc and select the correct pads.
Search google for the info and you get....
http://www.justparts..._2000-2007.html
Use yer 'ead and pick the right ones off ECP's (admittedly ****e! ) website. :)
Fabia doesn't have the brake pad wear indicator thingy to worry about and remember the forum discount code... Or use a better one if you can find it.
J.
Edited by vindaloo
Car parts for less is £1 something cheaper haha. I'm getting confused with all this brake system stuff.. Coming up with teves and Lucas. Does the pads differ for the different calipers?
There are different types, with and without wear sensors
