skoda octavia central locking fault
hi i have a 2001 skoda octavia elegance 1.9 td and only recently the central locking has started locking on and off even when driving or left alone and not pressing buttons it just keeps switching on and off and advice please as stuck
I had the fault of the doors locking & unlocking whilst driving along & i replaced my ignition switch & this has fixed it,mine is a mk2 octy though. You will get a better reply from the guys on the mk 1 octy section,maybe ask a mod to move this post for you. :thumbup: Welcome to the forum!
Its most likely the door control unit in the drivers door, its attached to the window motor
Looks like this
It gets water in and starts playing all sorts of tricks
Sent from my iPhone 4s
hi thanks for the help guys will have a look i guess this door control unit aint cheap either or easy to fit????? but thanks for the help and warm welcome :thumbup:
Becareful when you pull the multiplug off incase some pins are rusted, spray it with wd40 inside to remove the water let it dry then pop it back together
thanks brownbarge i'll remember that and do i need to set anything electrically or is it just a simple unplug and plug in new one or should i go garage ?? :wonder:
You may not need a new unit unplug the plug allow it to dry out and plug back in
