Rear door central lock not working (many fault codes)
Hi,
I noticed that my left back door was not locking even every other door were. Another symptom was that same door windows was not operative from drivers master panel, but worked from door own switch...
And here is diagnostic output. Not sure what is causing what but quess they might be related to same problem.
Thanks in advance. I have checked quickly connectors on pilars. Only trailer fault disappeared with clearing DTC, others appeared again. Car is combi 2009 1.9 TDi octavia
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 69 72 77
VIN: TMBGS61Z292041143
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010 :sweat:
09-Cent. Elect. -- Status: Malfunction 0010 :sweat:
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010 :sweat:
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010 :sweat:
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010 :sweat:
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100 :sweat:
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 TG HW: 03G 906 021 AB
Component: R4 1,9l EDC G000SG 2051
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 73430 000 00000
VCID: 77F6E982399752A4
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B201C092600FB880C04E8901C00412800
Shop #: WSC 73430 790 00999
VCID: 74ECDE8E28E139BC
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AC HW: 3T0 907 044 AC
Component: Climatronic 122 0203
Revision: 00003001
Coding: 0100000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SK35.rod
VCID: 73EEDD922DEF3E84
1 Fault Found
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [009] - - - MIL ON
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Reset counter: 137
Mileage: 70241 km
Date: 2047.14.15
Time: 07:29:07
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 HW: 1K0 937 087
Component: BCM PQ35 H 020 0358
Revision: 00020000
Coding: 40180AB8D00508C040080080110011E4010000AE626D85605C0440000000
VCID: EED84CE6C6CD936C
Part No: 1Z1 955 119 C
Component: Wischer 13020 22 0601
Coding: 00D7B7
Part No: 1K0 955 559 AH
Component: RLS 180209 05 54 0402
Coding: 0730ED
1 Fault Found
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 137
Mileage: 70241 km
Time Indication: 0
Date: 2111.14.15
Time: 07:29:07
Freeze Frame:
Term 15 Off
Voltage: 12.20 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2B9SHU
Coding: 0020790
VCID: 3D7A3BAA5B2BB8F4
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CN HW: 1K0 953 549 CN
Component: J0527 053 0111
Coding: 0000034
VCID: 8004025EEC59951C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 D HW: 1Z0 920 843 D
Component: KOMBI H20 0106
Serial number: 00000000000000
Coding: 110F00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 39722FBA4F0384D4
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K092060353
Coding: E9817F46000602002302
VCID: 37762982791792A4
2 Faults Found
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 192
Mileage: 68465 km
Time Indication: 0
Date: 2110.14.07
Time: 15:43:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 137
Mileage: 70241 km
Time Indication: 0
Date: 2111.14.15
Time: 07:29:06
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H20 0106
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 N HW: 1T0 959 701 N
Component: Tuer-SG 008 2011
Coding: 0004342
VCID: 4280485622D5C70C
1 Fault Found
02071 - Local Databus
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 73430 000 90108
VCID: 356A238A631B60B4
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 N HW: 1T0 959 702 N
Coding: 0004342
VCID: 438E4D523DCFCE04
1 Fault Found
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 1507354
VCID: 346C1E8E686179BC
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 006 0039
Revision: 0H001001 Serial number: SKZ1Z2I8218226
Coding: 050004000001
VCID: 3162179A97734C94
Address 62: Door, Rear Left
Cannot be reached
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H08 0080
Revision: 3A002002 Serial number: 00000117152906
Coding: 4100000100000000
VCID: 2F6611E281475A64
2 Faults Found
02563 - Trailer; Right Tail Lamps (M61)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 70049 km
Time Indication: 0
Date: 2111.14.09
Time: 20:50:58
02566 - Trailer; Left Turn Signals (M62)
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 70050 km
Time Indication: 0
Date: 2111.14.09
Time: 20:59:10
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AK HW: 1K0 959 704 AK
Component: Tuer-SG 007 2001
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 7AF0F0B60A854FCC
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 A HW: 1Z0 035 729 A
Component: FSE_2P8x H34 0150
Revision: 00000000 Serial number: 00000005009143
Coding: 0010422
VCID: 366824867E1D6BAC
End ---------------------------------------------------------------------
Have you checked the wiring to the doors at the hinges for a possible broken wire? Its a common problem. I see you mentioned a check at the pillars, so it might be inside the rubber protection?
They all look linked apart from the hvac one which I have. Mine is caused by an updated facelift climate panel in a pre facelift car.
Adam
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 137
Mileage: 70241 km
Time Indication: 0
Date: 2111.14.15
Time: 07:29:07
I know that the date is fairly irrelevant on the car, but has anyone else noticed that the date is actually impossible? (However you want to read it)
Adam
thanks for your reply. I'll double check wiring. Another symptom was that I could not activate rear windows safety lock from the driver panel. Is it more likely problem on driver door wiring or on the problematic rear door and could it be under the panel ( I see there is fault for driver door as well)? And is wiring in a star model to every door from the driver door or are they chained (I mean could be broken in some other place, e.g. if wiring is chained from another rear door)?
about HVAC problem, it has same mileage and time stamp than this central lock problem under it, so it might be related to same problem as well?
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 137
Mileage: 70241 km
Date: 2047.14.15
Time: 07:29:07
thanks again
-Astir
I'm not sure about the wiring setup between doors but given the switch on the drivers door controls all four, they are all linked to it.
You might have hit on something with the date stamp. Its probably a canbus wire that is broken as the error is affecting hvac and the doors at the same and both are on the comfort can network. I see canbus is mentioned in one of the errors too.
I would be checking at the rear left first but reading the errors again its possible two wires are gone, so check all four doors.
Adam
Hi again,
well I did recheck and quess what I found, not one but 3 broken wires and all other had crack in same place!
Sounds like china quality to me even we have cold winters here in Finland. Now all fault codes are disappeared :)
Here are steps what I did if it helps someone in same situation.
1. initial situation
WP 000528
2. I put heat shrink tube to all damaged but not yet broken wires. Wires can be released from connector one by one
WP 000530
3. Then I soldered broken wires and put heat shrink tubes to them as well.
WP 000534
4. Finally it looked like this:
WP 000535
br.
-Astir
Edited by astir1978
Well done, good result. Which door was it in the end?
it was the drivers door.
-Astir
Yes and definitely the comfort can low was broken as suspected. Glad its sorted now anyway.
yes, thanks for calling out the wiring condition. Otherwise I could been write off them after first check...
br.
-Astir
Nice job.
