Central Electrics Controller (1K0937087)
Hi all,
A while ago I made the mistake of playing with the ominous byte 18, ever since then it's been a bit screwy.
I've got ADL and if I unlock the car @ night the lights come on as they should but if I get in and turn the ignition on when the main lights come on I get a bulb warning which comes back to a tail light each side.
However if I unlock the car and let the lights go out and then turn the ignition on I get no bulb warning.
To add to that recently I fitted footwell lights that work okay apart from channel 35 in adaption errors and I cannot adjust the brightness when the ignition is on. (no maxidot yet)
Also even with the relevant coding changes my LED licence plate lights still throw up a bulb warning.
So I've come to the conclusion I broke the CECM and want to replace it, all the coding I'm good on apart from byte 18.
If I buy a new one 1K0937087 they fit to nearly every VAG car out there.
Anyone got an idea other than getting a dealer to do it via VAS?
Nick
First you need to reset or recode byte 18. As for bulb warning I sometimes get for license lights and the conclusion I came is that it hasto do with the cars battery, a bit low on power. I think their was someone on here that had to recode byte 18.
Hi Alberg,
That's the trouble I don't know how to reset the controller or what the correct code/byte 18 is for the Octy due to it being masked out with "00".
As always I combed the site for answers before posting this and came up with nothing.
Nick
Will send PM
Edited by alberg
Hi Alberg,
Nick
Have you tried contacting Ross-Tech directly about this? They are usually very helpful and although may take a few attempts you might get your current module coding sorted.
There are only 255 combinations for byte 18 so one of them must be right. Well 254 as its not 00000000 :-)
Here are all the Binary combinations
http://tonystrains.com/download/DCC_DecBiHex_Chart.pdf
Edited by xpower
http://tonystrains.c...BiHex_Chart.pdf
Me and Dana went through it extensively to no avail. I should have adhered to the warning :)
No luck I guess, sorry.
I appreciate the help, possibly looking at getting a new/used controller. If it's used and doesn't come from an Octy I've gotta find out if it can be programmed by means other than the dealers.
Nick below is a list of the byte 18 codes I have found on the internet, the bits in brown I have added - basically just a quick translation of the codes) Normally I would not recommend anyone changing byte 18, but as you have done so already there is little harm, I cannot guarantee these are correct… but at least for my Superb they were.
1A - Škoda Superb Combi (SK462) - Halogen without TFL, DRL-LowBeams (without separate DRL’s - DRL by LowBeams)
1B - Škoda Superb (SK461) - Halogen without TFL, DRL-LowBeams (without separate DRL’s - DRL by LowBeams)
1C - Škoda Superb (SK461) - Halogen RoW separate TFL_1 (separate DRL’s with DRL outputs)
1D - Škoda Superb (SK461) / Škoda Yeti (SK356) - Xenon ASUV TFL_Separate (separate DRL’s)
31 - Škoda Superb Combi (SK462) - Halogen ?? separate TFL_1 (Separate DRL’s with DRL outputs - Bi Xenon's)
32 - Škoda Octavia (SK350)/ Škoda Octavia RS (SK35x-RS) - Halogen RHD TFL_LED ROM from TFL (LED DRL ’s)
33 - Škoda Octavia (SK350) / Škoda Octavia RS (SK35x-RS) Halogen LHD TFL_LED ROM from TFL (LED DRL ’s)
34 - Škoda Octavia (SK350) / Škoda Octavia (SK351) - Halogen RL (RHD) RL from TFL ROM 52 ROM from TFL(DRL’s)
35 - Škoda Octavia (SK350) / Škoda Octavia (SK351) - Halogen LHD TFL_1.separat LL halogen-ROM from TFL (separate DRL’s with DRL outputs)
36 - Škoda Octavia (SK350) / Škoda Octavia (SK351) - Halogen RL (RHD) DRL-LowBeams (S)(P) (DRL’s Low beam)
37 - Škoda Octavia (SK350) / Škoda Octavia (SK351) - Halogen (LHD) DRL LHD-LowBeams (S)? (DRL’s Low beam)
38 - Škoda Octavia (SK350) / Škoda Octavia (SK351) - Halogen RL (RHD) TFL_SH (DRL’s via shutter)
39 - Škoda Octavia (SK350) / Škoda Octavia (SK351) Halogen (LHD) TFL_SH (DRL’s via shutter)
5A - Škoda Octavia (SK35x) / Škoda Octavia RS (SK35x-RS) - Halogen / Xenon RL (RHD) LED, TFL from Shutter (Xenon low beam + Halogen high beam + LED DRL’s)
5B - Škoda Octavia (SK35x) / Škoda Octavia RS (SK35x-RS) - Halogen / Xenon LHD LED, TFL from Shutter (Xenon low beam + Halogen high beam + LED DRL’s)
74 - Škoda Superb (SK461) - Halogen / Xenon China - China without DRL SL with BL-function LED SBBR
Xenon low beam + Halogen high beam (LED rear lights)
75 - Škoda Superb (SK461) - Halogen / Xenon China - China without DRL / TFL-ABL SL without BL-function LED SBBR Xenon low beam + Halogen high beam (LED rear lights)
As for the LED numberplate lights IIRC the coding only works on MY13 onwards cars.
I tried every code possible and still no cigar!
Anyway's the controller is being replaced next week.
Nick
All 255 combinations? I'm surprised none of them worked. The 00 must be more than just a 'mask' then
Nah, I meant all Skoda codes :)
I was just told to try the combination    C0  (C and zero)
Was also informed that your not the first to have the ECU fail after messing with it on byte-18
Edited by alberg
Yeah I think the controller is faulty when it comes to external lighting so on Tuesday it will be replaced and factory coded, so I'll have some coding to do Tuesday afternoon. :)
