Sprintbooster - anyone actually tried one?
To me it seems rather overpriced but an interesting idea.
It's supposed to remove the DBW throttle delay and make it more like a cable throttle.
Basically by changing the characteristics of the pedal.
http://www.sprintbooster.co.nz/
I like this explanation from here
Pedal Travel: |----------------------|----------------------|
Percent:.........0.........................50%.... ..................100%
Spring Booster Travel/Throttle Relationship:
Pedal Travel: |--------------|---------------|---------------|
Percent:.........0...............50%.............1 00%............100%
So you see, all it does is decrease the travel in the pedal in relationship to throttle position.
So where you saw 1/2 throttle before in the pedal, will now be (for arguments sake) 3/4 throttle.
Essentially making response greater, but adding no power whatsoever. I actually was considering it because the drive by wire lag gets annoying and even makes my lightweight flywheel seem sluggish responding.
Some interesting opinions here:
http://www.vwgolf.net.au/showthread.php?4395-Sprint-Booster-Installed-and-lovin-it!
Everyone who has one says it's great.
At that sort of price id get a remap and then you deff will have more throttle response :)
Total utter snake oil :rofl:
You can program a FBW throttle to behave however you want it, and they're not slower responding than a cable - their faster !
Exactly, it reprograms the throttle.
But how would you program it? Part of the map?
Yes, part of the map
You can program it however you want
If you wanted 75% of the throttle controlled by say the last or the first 25% of movement of the pedal, this is programable
Most mappers put a more aggressive throttle response into their maps to aid the impression of more immediate power
The downside of an aggressive/sensitive throttle map is reduced MPG (unless you've got cruise control)
If you wanted fuel economy a throttle map like this would be better
Pedal Travel: |----------------------|-----------|-----------|
Percent:.......0...........................30%.......50%.......100%
Super lazy setup
I bet they would sell well at 1/5 the price.
My track car was remapped to have linear throttle.
It is like driving a normal cable throttle car now (so you can actually balance the car with the throttle pedal through the corners).
