VAG IMMO PIN READER 2009+
Hi,
I used VAG COMMANDER 5 on my car to match new FIS/Maxidot Cluster, but it's not compatible with a friend with a skoda octavia 2010 restiling.
It seems to have VDO with NEC 24C32 eeprom, witch is not compatible with VAG Commander 5.0.
Anyone knows the correct "china" cable to get the PIN? AVDI - Arbitrus and VAG KM + IMMO tool seems to work but are so expensive (> 500€)
Many thanks.
Forum rules do not allow the posting of any links to counterfeit software or hardware or similar. Sorry.
where are you based, I have genuine Vag-commander 19
Sorry I don't want illegal things, You can delete this post if you think It's inapropiate.
I want to know if there's a specific cable, only the name, later I can try to find myself on ebay
My friend bought an used cluster, we thought It was similar to my car, but It's different, and dealer says It cannot mount without pin. There are electrical mechanics near here, but only work on octavia mk1 (there are a lot of taxis with a cluster problem), nothing for mk2.
Eddie I have can commander 5.1, but It cannot read on facelift octavia, many thanks for the offer (I'm spanish)
Edited by de_compet
you need to put the cluster into service mode to read pin
so you need a newer version of commander
what are you looking to do?
We want to get pin, then try to setup the cluster or go to dealer to set up
Witch is the correct version of K+can comander for facelift? Is it immo 5 or immo 4? Is it EDC or MED 17? I know that is a VDO with NEC chips.
(Remember that It's for my friend with a 1.9 tdi CR skoda octavia facelift, maybe can I see EDC version on VCDS)
Newer car with NEC will be immo 5
Online access at dealer or Vag commander 19 to change cluster
is the cluster new or used?
Many thanks Eddie-NL
It's used (sold from a crashed Car), he needs to reset to factory or get pin, then he can go to dealer to setup.
I'm trying to find version 19 but not reach them, 19? or 1.9? only found 5.5+pin reader (not valid for facelift) and expensive 8.x, AVDI or km+immo tool are out of my scope too
It's easy to find crashed cars, another friend want to buy thIs (here most taxis drive a skoda) http://www.segundamano.es/barcelona/despiece/a44862356/?ca=8_s&st=a&c=53 but I'm not sure it could be fitted without headaches....
