Can I tow it?
Hi Guys
Following on from my thread earlier in the week my gearbox went bang.
Got underneath it on tuesday to find this.
2013-06-24 18.25.18 by mattrsa, on Flickr
2013-06-24 18.26.45 by mattrsa, on Flickr
I'm guessing the gearbox has had it based on what I have read in other threads. The car is outside my house so my question is can I tow it using my other car to the garage or will it do even more damage? or do I need to get it on a flat bed which is going to cost a bomb.
Can you remove both drive shafts? No chance of any more damaged being caused / making the repair bill bigger
Just been recovered by the AA the exact same thing has happened.
Cover missing and some of the balls out of the bearing.
No idea how its happened.
Aslong as its in neutral you should be fine,
Looks more internal rather than the diff.
Don't be taking the shafts off. You'll and up damaging the wheel bearings.
on most cars yes, but on a Fabia no as the bearings do not use the driveshaft to preload them, removing the driveshafts is the safest way of ensuring that nothing jams up and causes an accident while its being towed.
But if it is not far and you go steady I recon it will be ok
Thanks guys. The garage is only about 3 miles away so fingers crossed it will be ok. Don't fancy calling out a flat bed which I suspect will be over 100 quid
