Coolant Pump B
I have the fault code P261A, and have a price for the item of £45, question is where is the pump located and is it easy to locate. As much information I can gather from the Briskoda brains will be very much appreciated. Thank you Diane.
It sits under the car in front of the sump. Quite easy to spot with the under tray off. Can be a bit of a bugger to change as its quite tricky to get on the screws securing it to its bracket. Clamp the hoses before removing them and you won't loose much coolant.
